very dangerous to do that. if you're at a bad spot on the timing belt (i.e. tension is on the cams from depressing the valve springs), the cams WILL rotate when you loosen the belt and possibly cause piston to valve contact. TDC is a good place to have the motor rest where there is minimum tension on the cams.Boardman wrote:you DON'T need to set the engine/cams at TDC.remove the crank pulley and lower cover,get some liquid paper and make marks on the old timing belt where it lines up with the cam sprockets+crank. loosen the tensioner- remember which way the spring goes!!remove belt- don't move any engine parts.liquid paper the new belt in the same spots as old belt- and install it- tighten tensioner- you're done.
MY NEW BEST FRIEND!!!! I would love it if we could get together sometime. I am pretty inexperienced with engines and while I'm not afraid to get my hands dirty, I am pretty nervous about timing belts. I just don't want to risk blowing up an expensive engine. If you are willing to help me out I would GREATLY appreciate it.PsiloX wrote:TDC means Top Dead Center. To be in TDC you have to move the no. 1 cylinder to its top most postion of the stroke. Usually this requires the removal of the spark plug in the No. 1 to check is position.
All your marks should be lined up at that point.
Hope this helps. If you really run into problems I only live in Oshkosh and I've done it before.
It's not dangerous chicken little- oh noes- the sky is falling!!You can try and make up excuses and scenarios to support getting the engine to TDC.But it's not needed. Do it if you want- but you don't HAVE to.gawdzilla wrote:very dangerous to do that. if you're at a bad spot on the timing belt (i.e. tension is on the cams from depressing the valve springs), the cams WILL rotate when you loosen the belt and possibly cause piston to valve contact. TDC is a good place to have the motor rest where there is minimum tension on the cams.
They aren't excuses. That is the number one reason for setting to TDC.Boardman wrote:It's not dangerous chicken little- oh noes- the sky is falling!!You can try and make up excuses and scenarios to support getting the engine to TDC.But it's not needed. Do it if you want- but you don't HAVE to.
Sorry, the cams WILL NOT rotate when you loosen the belt "And possibly cause piston to valve contact" <- that was funney, LOL.
Go to harbor freight and get a stethascope. Touch it to components and listen for the noise. You'll isolate it sooner or later.Eikon wrote:
If the belt is tensioned properly, what else could cause the noise? Something with the cams? Maybe a bad idler/tensioner?
Thanks for the pics Boardman!
Thanks again for everyone help and imput!!!!
LOL... I can see where that might cause some pain.Nameless EJ6 wrote:
PS: obviously don't touch the end on a rotating part. That may hurt.
why be an *** about it? i realize the cams arent gonna go flying when you loosen the belt, but they can definitely turn a few degrees. i have seen it happen on a 4g63. why not do it right and put the motor where its happy? maybe you've changed a bunch of Tbelts this way and saved a whopping 30 seconds each time by not putting it to tdc. yes, chances are its going to be fine, but why take the riskBoardman wrote:It's not dangerous chicken little- oh noes- the sky is falling!!You can try and make up excuses and scenarios to support getting the engine to TDC.But it's not needed. Do it if you want- but you don't HAVE to.
