Please help w/ transmission noise. 95 s14
goldeneye9mm
Car: 95 S14 240sx
ok heres the down low. i spent like 10 hours putting in a new clutch and slave cylinder today and now the transmission makes a werring noise. i cant tell where its coming from and i'm hoping there's some easy fix for it. i replaced the clutch, flywheel, throwout bearing, slave cylinder and crank sensor cause i broke it. the only thing i couldn't do was the pilot bushing cause i didn't have a tool for it. i got it to make the noise in neutral but as i was going through gears in the air it made i as soon as i hit third and didn't stop till i turned the car off. the clutch pedal feels a lil soft but not horrible. i bled the slave like 4 times. please someone make any suggestion please.
rogoman
Car: 1991 240SX FB
2012 Altima 2.5 S
Does the noise go away when you press on the clutch pedal? If so, then the transmission input shaft bearing may be going bad.
goldeneye9mm
Car: 95 S14 240sx
well likr i said i got it to make the noise in neutral and in gets loud in third. i didn't go past third to see but the first time it didn't stop till i turned the car off but it was gon when i turned it back on like 15 seconds later. i really don't want to dump a lot of money at a transmission shop but i don't want to take it back apart eather. arge. any more suggestions?
goldeneye9mm
Car: 95 S14 240sx
bump for more suggestions
rogoman
Car: 1991 240SX FB
2012 Altima 2.5 S
rogoman wrote:Does the noise go away when you press on the clutch pedal? If so, then the transmission input shaft bearing may be going bad.
You didn't answer my question!! Does the noise go away when you press on the clutch pedal?
goldeneye9mm
Car: 95 S14 240sx
no it didn't go away the first time till i shut the car off. no matter what i did. but it stopped on restart. i fooled w/ it and it started again but not as bad. sorry i thought i implied that.
rogoman
Car: 1991 240SX FB
2012 Altima 2.5 S
Were the flywheel bolts properly torqued down?
goldeneye9mm
Car: 95 S14 240sx
yeah i made sure all the bolts were torqued in sequense and properly.
goldeneye9mm
Car: 95 S14 240sx
never mind i took it on a test drive and the noise went away sooooo i dunno. if it comes back i'll drop it off at a transmission shop. i'm not doint that again any time soon.
