Newcastle82 wrote:You did just lower your car - y ou ARE going to align it, aren't you? Be good to those tires!
Absolutely! I still need to replace the worn T/C bushings before the alignment. Thanks for the strut (sway?) bar tip. I took a look and the top part of the passenger side endlink, when looking down from above, is not perpendicular to the bar. I'll try to fix that and see what happens. I had installed the driver's spring upside down, which I think contributed to the camber problem. The driver's side tire is also too far forward within the wheel well, but that may also be due to the sway bar or to the shot TC bushings. Could this be called excessive negative caster? (just trying to get my terminology right).
ps. big ups to enjuku for quickly sending me replacement AGXs - those guys are great.
