paulkornya »
https://forums.nicoclub.com/paulkornya-u65038.html
Thu May 10, 2007 7:28 pm
SUMMARY: Car runs great, then I broke the MAF connector, the car runs like crap for about 30 sec under 2000 RPM with no MAF, Sodered the connection on the old MAF, didnt fix it. Then I bought a new MAF, still runs like crap; like it did with the one I tried to fix. Car runs close to the same without any MAF and with new MAF, only difference is it doesnt die at idle. DETAILS:
I was being a retard the other day cleaning some stuff on the air filter and box on my 93 240SX 5 Speed, SE
So when I was removing the MAF I unscrewed the 2 small screws on the top of the MAF near the connector and broke the connection taking it off, ( I didnt know how to get the clip off, but now I do! )
I cranked the car after trying to fix it and the connection was bad and the car was running like crap and dying at idle, I only ran it for about 30 Sec. Obviously dumping way to much fuel into the motor. Naturally as I broke the MAF and it was running without one.
Also when I playing with the connection that I broke with the car on (ON, but not running) i could hear the connection clicking when I moved it back and forth, however the clicking sounded like it was coming from somewhere to the left. Like click on then off, So I take apart the MAF and soder the connectors back to working order.
I install the old MAF back on the car, start it and it doesnt die at idle however it does run like crap (RICH) still and doesnt rev over 2000, there is also a large amount of smoke coming from exhaust, smells like it's running rich. It also runs very very ruff and the motor shakes badly. I tried to let it run some of the fuel out but it didnt get any better after about a minute i turn it off.
So I buy a new MAF from a reliable source. Install it, Put BRAND NEW NGK Plugs in, start it up. SAME PROBLEMS! So I take it there is something else wrong. I check the plugs, Im getting plenty of spark, check the plugs, they smell like gas badly so I know it's running rich.
I get no check engine lights. I tried to see if I could hear the clicking noise again by unplugging and plugging the clip from the MAF. I cant get it to do that.
I also took the battery out for about 3 days waiting for my New MAF so unless I need to reset the ecu another way... I thought that would reset it.
Im going to check the grounds tomorrow, but what else would it be?
