PLEASE HELP. Very close but not quite...
hokiruu
Car: 2012 INFINITI M37X Platinum Graphite
'95 240sx/s14 SR20DET (in 2000) SOLD
I have ALOT of questions so please bear with me:
I have had the my s14 SR installed since August but have been unable to get it to start. The problem seems to be that my coilpacks are not firing. Last night I was trying to troubleshoot my SR wiring again and ran into a few interesting things. Using a test light, I was able to get current from each of the connectors to the coilpacks. However, when I pulled out the coilpack and flipped the spark plug to see if it would fire, nothing. I then checked for current at the igniter chip. There is an arrow on the ignitor chip. I get no current from the connector behind the arrow, but I do at the connector on the side the arrow is pointing toward.
Does this mean that my ignitor chip has a problem?If so, is it possible that I could have power going to my coilpacks, but without the ignitor chip, they won't actually fire?
There are red, white, and black wires to each of the coilpack connectors (+, -, E). What does the "E" stand for? Could one of these wires being dead still allow for a signal at the connector overall and still keep the coilpack from firing? Would that be related to my ignitor chip?
Another strange thing is that somewhere near the ignitor chip there is a small female two wire/pin connector that doesn't seem to have a home. One wire is black and orange, the other is brown. It has current. When we looped both pins, it blew the fuse to the fuel pump. But with it still disconnected, my fuel pump seems to work fine, I hear it whine when turn the ignition on for accessory power, and i smell gas when I crank the engine, as well as a "gulping" sound. What is this connector for?
And finally, I can't seem to find a connector to plug into my oil pressure sending unit (at least I think that's what it is- yellow plastic connector off a metal cylinder coming off the block on the passenger side). Does the SR have a feature that cuts off fuel or spark if there is no oil pressure signal? Where should the connector for that be/where does it go? Sorry for the extremely long post and tons of questions, but I am very close and this is all I know. Can anyone help me?
S13240
hokiruu wrote:I have ALOT of questions so please bear with me:...And finally, I can't seem to find a connector to plug into my oil pressure sending unit (at least I think that's what it is- yellow plastic connector off a metal cylinder coming off the block on the passenger side). Does the SR have a feature that cuts off fuel or spark if there is no oil pressure signal? Where should the connector for that be/where does it go? Sorry for the extremely long post and tons of questions, but I am very close and this is all I know. Can anyone help me?
The connector is sheathed with a rubber cover over the one wire plug. I'm sure if you look around for a one wire connector plug with a rubber cover it'll be around your fuel filter/intake mani. area.
And no it the SR does not have a feature that cuts off fuel or spark with there is no oil pressure signal because I drove my car several months without that connecting the oil pressure sensor.
BTW, it sounds like your wiring may be connected wrong. Recheck all your wiring if you haven't so already.
EL240SX
Car: cars
Hokiruu the oil pressure sending unit should be very close to the oil filter and is screwed into the block like S13240 said. It also seems like your ignitor is bad but I could be wrong. I will also ask my uncle who is a mechanic that helped me do my swap what he thinks about it.
hokiruu
Thanks guys! Yeah, I need to know if my ignitor is bad.
EL240SX
Car: cars
Hokiruu I asked around about your ignitor delima, and everybody said that you have a bad ignitor.
hokiruu
Awesome! I mean that sucks my ignitor is bad, but at least i know now. Thanks EL, I really appreciate it a lot. As far as other progress goes, I finally finished installing my Blitz SBC DC boost controller, FATT, and Greddy warning boost gauge yesterday. the thing that sucks is my tiny Odyssey PC680 battery that Wayne from Phase 2 recommended is having a hell of a time supporting even these three pieces of eletronics. I am going to spend this week trying to figure out how to get my Silvia gauge cluster to work on my car. Looks like I will be dissecting both their insides to create a frankenstein S14 gauge cluster.
