MiniR34 »
https://forums.nicoclub.com/minir34-u16169.html
Fri Jul 29, 2005 4:09 am
Sorry about bringing back a thread from the dead, but I'm hoping people can use this information.
I finally got around to changing the clutch this weekend, and the shudder is completely gone.
Before doing the clutch, I tried a few different things. First was SPL Parts Subframe Collars. The whole subframe was shaking during the shudder, so I tried this easy fix with no results.
After that, I removed the clutch dampener, also with no results.
The clutch job took me about 20 hours. 8 of those hours was spent with me trying to fit the transmission back into the engine.
I don't know exactly which part was causing the shudder/clutch pedal pulsation, but I'm leaning very strongly towards the release bearing. When looking at it while it was on the release collar, it looked crooked. I thought it was a really bad mounting job by the previous mechanic, but it is impossible to misalign it. I then discovered that the rotating surface of the bearing could be moved around sideways. I'll try to take a picture of it later.
The replacement release bearing I received with my kit looked about 3/4 to 7/8 of the thickness of the old one - any cause for concern there?
Also, the pilot bearing was worn quite badly on one side, but I think that was caused by these other issues, not causing it.
