dldjros69 »
https://forums.nicoclub.com/dldjros69-u76726.html
Sat Jul 02, 2011 5:38 pm
Yo man you really need to search the forum. There are 2 boosted 2.5s. I'm one of them and Scott is the other. I'll try and answer some of tour questions.
I have a 6 speed, I first started running 5 psi but now I have a manual boost controller. It's set to 9psi and can b turned to 10psi max. I am also running an uprev flash! No stand alone or piggy back bs. Finally your cvt will not hold up to the massive power increase. Yes you will be able to rebuild it. Yes it will break again. Also get your check book ready! A turbo application ain't cheap.
