please help tucson az
ygostr8
im desparete for help if any1 is willing to help me with my rb s13 its been 2 months and still cant drive it, help a brother out im willing to pay.please lmk [email protected]
Joe
whats wrong with it?
ygostr8
car still wont run, it turns on and stays on but once u give it gas its starts choking and itll just shut off, my ecu has code 55 so i know its not that, unless its messed up, also i tried my ecu and maf on a different car with a rb and the other motor ran good so i know those r good any idea btw r u in tucson?
wawazat8402
Car: 89 Sil80- RB25DET
Seen this happen before. Is there a chance you forgot a plug or tape anywhere in the intake tract?
Joe
what side of tucson are you on?
ItzGenX
Car: Smoke Purple 95' S14.5. Powered by the "Iron Man".
That happened to my first SR swap. Unplug the maf and start it and see if it works then (should be in safe mode and have an early rev limit). When I unplugged mine it ran fine to 3k rpm. Plugged the maf in, started but if I even sneezed on the gas pedal, it would stutter and die. It is worth a try. Also check your tps voltage too.
ygostr8
nope everything looks plugged in, vacuums and all.
im in south side by 12th ave lmk if ur down to help so i could tell u how to get here.
ill give the maf thing a shot.thanks.
ygostr8
does anyone know how a rb20 would run if the CAS was set wrong cause im thinking thats my problem.
