NISTECH »
https://forums.nicoclub.com/nistech-u7581.html
Mon May 17, 2004 10:34 am
no i suggest you check for water or oil in the spark plug well. If that checks ok pull the plug and inspect it. if it looks ok break out the ohm meter and check your resistance on your plug wire. if it checks ok check the resistance of the injector. You could just slap parts on it if you find that easier. But the injector might cost ya. I really dont think cleaner would resolve a problem severe enough to throw a code.
