this is the story: my 240 was idleing erratically, so i took it to the mechanic, the mechanic did a diagnose on the car:
1.- needed an EGR valve ... done, just sat a new one
2.-o2 sensor..................changed last night
3.-ideler control valve.......waiting on it
4.- transmission oil and filter change....i just did... but after all this changes my car wont start... i wonder what else went wrong, i have thinking about changing the fuel injectors, since the ones it has are called "viper" it was the cheapest i could get at that time (almost 4 years ago) groomits are a cracked so i dont know if this could cause my car not to turn on... i cheked the spark plugs they are fine, i will change my distributor cap and rotor as soon as i get them , i checked the fuel pump is ok so i have spark, fuel, but no ignition!! do you guys have an idea on what could it be? im desperate! please HELP!!
