PLEASE HELP!!!
onebadg35
Car: 2005 blue g35
ok time to pick your guys heads...... my car is a 2005 g35 coupe A/T. i did a oil change recently (4 mths ago) lol but i started to notice a little tick from my motor when i was checking my tire pressure. so i poped the hood and checked my oil and it wasnt even on the dipstick!!! scared i might have ran it to low i got 3 courts of royal purple (5w30 syn.) and finally got it to show again on the dip stick. i did a little research and i see they had a oil consuption problem ..... now from what i can see its only on ones with 6sp M/T? i dont get ehy the stick shift option would make a difference but i guess it does.... so now im puzzled my car just turned 70k and runs great! i put it on a lift and theres not one drop of a oil leak to be found anywhere ...... my car dont smoke at all and it leaks no oil....... im lost.... please help...... :wtf2:
telcoman
onebadg35 wrote:ok time to pick your guys heads...... my car is a 2005 g35 coupe A/T. i did a oil change recently (4 mths ago) lol but i started to notice a little tick from my motor when i was checking my tire pressure. so i poped the hood and checked my oil and it wasnt even on the dipstick!!! scared i might have ran it to low i got 3 courts of royal purple (5w30 syn.) and finally got it to show again on the dip stick. i did a little research and i see they had a oil consuption problem ..... now from what i can see its only on ones with 6sp M/T? i dont get ehy the stick shift option would make a difference but i guess it does.... so now im puzzled my car just turned 70k and runs great! i put it on a lift and theres not one drop of a oil leak to be found anywhere ...... my car dont smoke at all and it leaks no oil....... im lost.... please help...... :wtf2:
Mine has used oil since day one. You need to check your oil weekly. The L mark on the dipstick is two quarts low and I've never let mine go below the 1/2 way mark to L which is one quart low. Mine still runs like new. I use 5w-30 whatever is on sale and change oil every 3k-3.5k miles
Telcoman
onebadg35
Car: 2005 blue g35
called infinity and they told me #1 i was running 5w30 royal purple and my motor i guess to there knowlage dosnt do well with synthetic oils. so what the service tech told me was i need to get it to a place asap and get the oil changed and try running 10w30 instead of the 5w30. so needless to say i just got back from picking it up from having the oil changed back to (dealership used mobil 1) 10w30. hope it helps ......
kmckis1029
Car: 2016 Q50 RS400 AWD
2010 G37x w/Prem, Nav, & Wood (sold)
2005 G35x w/Prem C (traded in)
guess they want you using a thicker oil... sorry you have to buy oil twice... :smh
Kendahl
Car: 2008 G37S, Blue Slate, Premium, Navigation
How many miles did it take you to go through 3+ quarts of oil? If it was less than 3,000, you do have a serious consumption problem. Do you see any leaks? Has the consumption rate increased recently?
Consumption up to a quart in 1,000 miles is still considered acceptable. You can buy a lot of oil for the price of a rebuilt engine if you have to pay for the rebuild yourself.
I don't see the difference between 5W30 and 10W30. The first number only applies to a cold engine. Both are 30 weight at operating temperature.
I run 5W30 mineral oil (Valvoline, not that it's any better than the others) rather than synthetic. Synthetic is specified for some cars (typically German) and I would run only synthetic in them. However, after reading what Blackstone Labs has to say about oil, I decided that there was no significant benefit to the extra cost of synthetic. I change oil and filter every 3,750 miles. Since my car often sits at home for several days in a row, I don't worry about the time between changes.
