Please help
Driftin'240
Car: TBA
Hey guys, I know everyone is just gonna tell me to "search" this topic. I did, and I found nothing productive. Anyways, I swapped an 1998 KA24DE into my hatch, started, everything ran perrrfect, minus the infamous timing chain rattle. I removed the top chain guide, to check the chain, and the lower hydraulic tensioners. Moved them around, made sure everything was tight. To check all this, I had removed the upper timing chain cover, with the dizzy in it (didnt remove the dizzy from the cover) Put it all back toghether and used gasket maker to seal it. Car wouldn't start afterwards, so I spun the motor to TDC according to the cam sprocket marks, then lined up the dizzy to where it's supposed to be. Still no start This is all a week before I get my G2 and get my car on the road Any help/suggestions would be greatly appreciated, thanks!
biggie
Would guess the dizzy is one tooth off.
