NISTECH wrote:try holding the throttle to the floor and crank it. if its flooded ,after a bit of cranking it should fire up. your base idle may be to low and its choking on fuel. it needs more air in colder temps to fire since the fuel does not atomize as well.
My apologies for Hijacking this thread.
Nistech, I am a new 240 owner and this is the only way I am able to start my car when it's cold. It happens only the first time and only after having sat for hours. Could you please explain this a little more? Let me add I know little about cars, sorry.
Does it hurt the car to throttle it in such a way? Mine certainly feels flooded as you described.How can the "base idle" be adjusted and does this have anything to do with the reg. temp idle? My car, when warm idles nearly perfect and does not even have the infamous 240 shake.
Thanks so much.
