silkysmoothyjud »
https://forums.nicoclub.com/silkysmoothyjud-u50966.html
Mon Jun 29, 2009 6:14 pm
ticking, battery terminal connectors bad (been there)........transmission, why did you flush it???? It should be done very slowly with high mileage (if at all). Try a bg flush to compensate, check your fluid level, too low=slippage....Quart or so low=lock up in a gear (been there, many times)
One transmission flush per transmission @ 60k. Then do it slowly (1 quart per month) when problems arise. Its a big gamble (ph/detergent shock factors). If your car does not overheat, you can go a looooooooooooooong way on MERC III if you dont mess with it....
"OH my transmission is hard shifting, jerking me around, its going out." NO ITS NOT ITS YOUR FREAKING FUEL SYSTEM. Injectors on this car (94)are troublesome to say the least. The injectors (not to mention the fuel pump) will cause all kinds of hard shifting issues, especially if more than one is failing hard....I should know, Ive replaced them all. One failing injector will make your knock sensors act like they are hung over....
I now barely press the accelerator, rpm never goes over 2.5 with a NICO ECU under normal driving. I cant afford new tires or to speed anymore for the time being....
Modified by silkysmoothyjud at 9:35 PM 6/29/2009
Modified by silkysmoothyjud at 9:36 PM 6/29/2009
Modified by silkysmoothyjud at 9:38 PM 6/29/2009
