please help
streetbikestunta420
Car: nissan 240sx/red top sr20det
my sr is leaking oil (alot) but only when running, i though it was the upper oil pan but i took it off and re gasket it and now it looks like its leaking just above it but i cant see,but what can leak only when the engine is running?turbo lines?
it all started when i hit something hard (my car is real low)
CSUPUEBLOTIM
Car: 1992 240sx Sr20det Coupe Silvia Front
I think this is one of those your gonna have to find it on your own situations. Not everybody "hits something hard" and gets the same leak you know? Get everything dry and look for cracks, drips or what not. Good luck.
hellonwheels8506
Car: 1990 nissan 240sx
I had a similar thing happen in one of my old cars, and the best way to find out where its comming from is cleaning everything spotless and running it, youll find it I promise
redsx13
Car: 93 240sx 03 350z
streetbikestunta420 wrote:my sr is leaking oil (alot) but only when running, i though it was the upper oil pan but i took it off and re gasket it and now it looks like its leaking just above it but i cant see,but what can leak only when the engine is running?turbo lines?
I would check your turbo oil line, that will only leak when running,and i had the same problem, but f**k me right?
streetbikestunta420 wrote:All I got to say is f**k u
