Please Help!
Texas240sx
I have an 89' 240sx with a 96' ka24de in it! Some man is selling me a 91' 240sx for parts! If I take the harness, ecu, and distributor off the 91' and put it on my 96' ka24de will the engine start? Also, will the 91' throttle housing bolt right onto the 96' engine! Thanks!
yellow_jacket
Car: 95 240sx
Pretty sure your O2 sensors will be different as the OBDII cars use a heated O2 sensor. Also the plugs for various things(like the tps, the o2 sensor, and maybe a few others) will be different.
Texas240sx
I am gonna get the whole car from him (91'). Right now I have a 96' ka24de in my 89'. Will the 91'dohc parts make my 96' engine run? If so which parts do I pull off the 91. I know the distributor, harnesss, coil, and exhaust manifold, but do I really have to change out the throttle body. The 91' looks way different then the 96's. Thanks!
Texas240sx
Can some one make a sticky or a how-to on installing a Ka24DE into an 89-90 240sx. Like what parts are needed from a dohc 91-94 that will need to be used when installing a 95' and higher ka24DE into a s13 sohc body. I can only find bits and pieces of info, but no exact info of how they did it. I can find nearly any how-to on swapping honda engines, but I cant find anything on the 240. Thanks!
