PLEASE HELP!
tx_widebody
Car: nissan 240
Okay here is my situation, i just bought a 90 240 that has a ka24de motor in it. I bought it for a whopping 50 bucks because he said it had a blown motor which was still a great deal i think. But anyways, i checked the motor out and it had two spark plug wires blown out, not to mention it had some cheap wires, so i pulled the wires out and the plugs, and the plugs looked ok.Next i did a dry compression check and i got 0 across all the cylinders, but then i put some oil in and did the check again and got somewhere around 125 on all cylinders. So i got new wires and plugs and tried to crank it, but it just cranks and cranks and finally after a while of just cranking it finally starts! The car runs good but when i shut it of and leave it for a while it takes forever for it to start up again. So does anyone have any ideas on why it takes forever to start up??
tx_widebody
Car: nissan 240
Anyone!!
180fan
Car: 89 fastback
assuming you're getting spark, check the fuel. If you're getting fuel, the 0 across the board will have something to do with it. Smells to me like worn rings.
tx_widebody
Car: nissan 240
Well i got the motor started it just takes a while for it to actually start.
s13_drftone
Car: S13 with sr20det swap
compression is low= rebuild, spark, timing
tx_widebody
Car: nissan 240
yup thats wat i am doin today
