TougeTune180 »
https://forums.nicoclub.com/tougetune180-u27541.html
Sat Oct 01, 2005 10:17 pm
so today i went and tried once again to correct my fuel pump problems. seeing as how this post is here, i had no positive results. i checked everything, found some corroded wires near the pump, so i rewired it and still nothing. then it dawned on me, the fuel pump is regulated by the ecu, and after checking power everywhere, i found that i didnt have any power in the circuit at all. then i remembered that when my car had died, it had popped a fusable link in the fuse box entitled "Engine Control" and so i am wondering if there could be a problem in my ECU, such as an internal short or soemthing that would cause the FL to pop. how can i check for that kind of problem, is there a possiblity that when it popped it messed up something with the fuel maps and possibly need to get it re-flashed? any help you guys can provide is greatly appreciated. thank you for your time
