Please Help!
knoxml
Car: 1994 Infiniti Q45
I just bought a 94 Q45 almost a month ago and it is running rough. It's stutttering and the idle is going down and then back up to where it was when I stop. It still runs and everything but I'm not sure why it shakes like this when I stop. No lights or signs are on. Please help.
96Qowner
Car: 1996 Q45
1.Check transmission fluid
2. Fiddle with the MAF connector while the car is running - see if changes.
More will chime in. In the meantime, this forum has an excellent search function - button in the upper right of the screen.
96Qowner
Car: 1996 Q45
Sorry, I was in a hurry and wasn't very helpful.
gniknave was having similar idle/stalling trouble and recently discovered that if the transmission fluid is low, it can cause a problem - the torque converter can lock up and cause the car to stall when decelerating. Check the fluid level and top it off, if necessary.
http://nicoclub.com/zerothread?id=102297
Problems with the MAF (mass air flow sensor) and its connector also cause similar symptoms. Here's a good article with pictures and instructions for cleaning the MAF
http://www.q45.org/maf.html
Modified by 96Qowner at 8:37 AM 1/17/2006
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Id also suspect an injector.....
96Qowner
Car: 1996 Q45
Procedure for checking injectors:
http://www.q45.org/ohminjectors.html
