Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Fri Apr 11, 2008 6:48 am
S14 SRs come with a ball bearing T28 turbo. It's not the same as the S15's, though.
As far as cam swapping goes, if he did swap the cams out, your VVT would have had to have been disabled. I don't believe that the S14 intake sprocket will bolt up to an S13 cam. I could be wrong though. Either or, the VVT is actuated by a big funky looking thing on the sprocket.
The S14 transmissions are rumoured to be slightly strongr, but I have a feeling that's more internet hearsay than anything. Internally, there's no major differences between the S13 and S14 transes.
S13 and S14 SRs use the same 370cc injectors. The pistons are the same as well, and trust me, you would know if he had swapped pistons out. It's not a fun and quick process to get the pistons out, plus it would require destroying the headgasket when you remove the head. And he wouldn't gain anything from swapping them out except time lost.
If you go to our RWD SR section and read the FAQ, I list out most of the major parts differences.
Anyways, what's leading you to believe that this guy is so shady and would steal?
