Please help.. retard here needs help
Roach
Car: 89 Z31
driver side top transmission bolt.. need it out... here's why it's not as simple as oh disconnect everything and pull the transmission out too... I made an engine lift. I was on a budget and got tired of staring at the useless blown motor in my 240 and the fresh s14 ready to drop in.. The tool I used wire... big a s s tree... duct tape to protect the tree... 3/16 teflon coated cable (rated for 400 pounds).. and a pulley from ace hardware (rated for 400 pounds.. here is my problem seeing as how motor alone weighs 317 or 371 or whatev)... how can I get that bolt out .. I'm a huge a** goon with big arms and the firewall is in my way of getting the wrench on it.. I can line up motor and transmission to loosen some but doesn't work since I can't get the wrench all the way on flush... I know this seems retarded so insult me if you wish only if you offer help.. thanks guys
krash
did you dry disconnecting all the mounts and tilting it a bit? that should give you more clearance to remove that bolt. Then put the mount back on and unbolt the bottom bolts
94_240sx
Car: 94_240SX
WHat you need is 3-4 feet extension.
caspers_240
Car: 91 s13 fastback
I never pull just the engine or trans for that very reason.... sry, but I don't think i would trust that 400lb rope.
Roach
Car: 89 Z31
ick... agreed but it wasn't supposed to be hard.. well then again it never is.... I'll try tilting it as suggested ps sorry guys for putting this in convertible section But thanks for the tips I'll try this weekend and let ya'll know how it works out.. also any quotes on how much a machine shop would bore my old block .20 over???
