ok so i was driving my fresh ka24de s13 and car dies cuz dizzy went bad replaced dizzy and now when i rev it up it sucks n air then revs up very weird.....so decided to take it for a test drive drove the car seemed to be doing ok besides missfire at lowrpm pulled into a drive way to back up and head back to the garage got stuck in driveway so had buddy push while i gave it gas and wasnt giving it to much but when we finnaly got out the car was making weird noises and was only firing on 3 cylinders so babied it home and pulled number 4 plug out it was smashed so i replaced that injector and plug and when i started it back up and it idled good but i was hearing a tapping noise that turned into a slight knock but then would go away so pulled plug again and the gap was closed btw this hole motor besides the crank is all brand new and yes crank was checked and it was fine so i removed my new bearing on the rod on that cylnder they look still brand new
any idea would greatly be appriciated
broken vavle spring maybe ?????
i know the piston it self cannot hit the spark plug becuase of the way the bottom og the head is designed so it has to be something else
