atgreene »
https://forums.nicoclub.com/atgreene-u232094.html
Sat Feb 22, 2014 1:50 pm
hey guys!, new to this forum with a new QX4!
Just got the car from a dealer with 148k miles.
drove it off the lot, everything worked great for about a week.
This week it started acting up. First, it wouldn't start, wouldn't crank, nothing. Jumped it and it ran fine for a day.
Wouldn't start the next day, so i took the car to O'Reillys and they tested the battery and alternator and they both tested fine. Car ran fine for another day.
Then went out to start it and it wouldn't start unless you feather the throttle to keep it from dying. also white smoke comes outta tail pipe while starting and giving it gas.
Looked under hood and saw a loose vacuum hose near the throttle body, reattached it and it started fine so i figured its solved.
Just went out to start it a day later and you had to give it gas to keep it running, more white smoke. Got it running and then turned it off to see if it would restart. Now motor just cranks and doesn't even wanta run at all.
Dealer said they put a new Mass Airflow Sensor in it.
Anybody have a solution or things to try? Really frustrating and i need this car badly!
PLEASE help!
thanks guys
