Please help.. question bout engines..
dubstyles240
Im writing a paper for my engines class comparing the reciprocating engine and the Wankel rotary engine.
anyways..... If the wankel only uses a few parts, is so small, so light, and so cheap to produce, why is it only used in the mazda rotary experiments?
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
Exaust gas heat and emissions would be my guess.
http://www.howstuffworks.com has a really good article on rotory engines.
Turb0wned
go to http://www.howstuffworks.com you should be able to find everything you need there hope it helps
Megaseth
Car: 2002 Pathfinder SE
they're also finicky to get working right. they're not the easiest engines to work on and not the most reliable. its a great concept, but it needs lots more refinement. and mazda is the only one still using them, but lots of other companies had them, even nissan.
JESTER
Car: 2004 Chevy Colorado Bright a** Red 3.5 five cylinder
RELIABILITY. The heat was the major problem with the 3rd Gen RX. Jump over to http://www.rx7club.com
Along with the article the other guys posted, these guys are the experts with the Wankle. Good group over there.
Megaseth
yep, the overheating problems killed the 3rd gen engines bad. didnt mazda lose a ton of money in warrenty claims of blown engines?
JESTER
Yeah from what I heard. I think it was suppose to be coolent leaks into the rotors caused by the excessive heat ( I could be incorrect on that). The turbo didnt have nearly as many problems until they slapped that twin up on the 13b-rew and just jacked the heat level up from the insane temp it already was.
Saw one guy on the rx7club that swapped a red top sr20 in his GXL. Took care of his reliablity issues.
