Then you are depending on the fuel pressure regulator to DO MORE WORK THAN DESIGNED.
What most don't consider is that there is also a fuel pulse damper in front of the rail [controlled by the air pulses in the area just after the MAF ........one of those 2 small air hoses.
The system was designed for perfection in acceleration as the 34>43.4 psi is 13% difference in flow.
Believe me they wouldn't have spent all the money for FPCU and other things if the oem method wasn't necessary........it probably added $250 to the cost of the car not an insignificant number considering it could have all been profit by just hooking the fuel pump negative terminal to the ground without the FPCU in between.
Plus I don't think you'll like the sound of the pump running wide open at idle not to mention the heat effect on the gasoline in summer from the always on 50 watt [pump] heater.
http://www.babcox.com/editorial/us/us50 ... au...pump/
The Walbro GSS341 model (also called the 255 lph HP) would be the best Walbro model for the 3000GT/Stealth................Q45!
http://www.stealth316.com/2-fuelpumpguide.htm#j4
