please help Power Steering
Bigrolla
OK i have a 90 240sx with a 91 ka24de swap. It has all the sohc ps hardlines bent to the driver side. The preassure hose is leaking so i need to replace and i was wondering could i just use the dohc preasure hose this time instead of the sohc one. I know the dohc one is long enough but i dunno if there is much difference in the connections. I know the side that connects to the power steering will work but i dunno abou the other end.
Bigrolla
just in case this ever comes up again it does work
180fan
Car: 89 fastback
yes, you can use the DOHC line and it will line up perfectly with your DOHC motor.
