Please Help! P1320 Code
AQuist68
Car: 2001 Pathfinder 3.5lx 4x4
Hey everybody!
I've been reading and studying your site and all your great wealth of knowledge for quite a while now. I've used it to help solve the few problems I've come up against.
The problem i'm having now is something i've been researching for quite a while, but I'm not sure what to try next... I'm getting the P1320 code, but no other misfire code. I replaced all the coil packs, but it didn't help. It has a hesitation when its warmed up and I rev it to right around 1700rpms. If i slowly rev it to 1600-1700rpms, it will quickly drop back to about 1400rpms even though I keep the throttle on a constant amount. It then will keeps doing this over and over as long as I keep the throttle on the same amount. It's almost like there's a misfire or something, but i'm not getting any misfire codes. When I'm driving it I can drive around with it in that RPM range and I don't feel anything. I have no idea what it is... Somebody said possibly a crankshaft position sensor?
I'd love to hear what you guys think.
Thank you!
asnorton44
Car: 2001 Infiniti QX4
When you replaced coil packs did you also do spark plugs? Also try cleaning your MAF.
AQuist68
I didn't do the spark plugs... Think it could be those? I have replaced the MAF about 500 miles ago tho.
asnorton44
Yeah when you replace coils you want to put in new spark plugs. Get some NGK PLFR5A-11 (6240) spark plugs, shouldn't cost much around $50. As far as a bad crankshaft position sensor it should throw a code, I've had to replace both of mine at 175k.
Towncivilian
2007 Nissan Altima 2.5L CVT
2012 Infiniti G37 Sedan 7A/T
You can obtain 6 NGK PLFR5A-11 (6240) spark plugs for $40.54 + tax at Advance Auto Parts if you order online with discount code RETMENOT123 and pick-up in store. There is a guide on changing spark plugs here.
AQuist68
I'll give those a shot. Just curious, if I had a bad spark plug wouldn't it throw a misfire code for that specific cylinder?
asnorton44
Yeah it should throw a misfire code but they may just be dirty and that is what is causing the weird RPMs.
AQuist68
I ordered the spark plugs and am expecting them tomorrow. I'll switch them out on Saturday so I'm praying that fixes this problem... these should come already gapped correct?
Thanks,
Azndjay
Car: 2001 nissan pathfinder
2008 Acura TL type S
2003 Acura RSX
ngk oem dont require gapping
Chuck Tribolet
Car: '01 Nissan Pathfinder
'87 Chevy Corvette
'01 Toyota Camry daily driver
'98 Boston Whaler Montauk
But I always check them. I have a gapping tool I bought years ago that takes about ten seconds per plug.
Chuck
AQuist68
Well, I replaced the plugs today, but didn't help anything... It's still doing the same thing and sounding like it's missing when I hit about 1700 RPM's... any other ideas from anybody?
