please help p/s sounds like s**t
Nissan 350z / Nissan 370z general community discussion forum
sir_vq
Car: 350z
whats up new to 350z crowd but need help when accelerating in low mid rpm range and turnig slight right my power steering starts to scream and it feels like there rocks in it if that helps fluid is good i took off the p/s cap and fully turned the wheel in both directions turn tryin remove any air anyone got any suggestions on possable problem
aris_unlimited
Car: 1998 Ford F150 4.6L 5 speed. Edge programmer, 2" lift, 35" tires.
I have no idea what you just said
rmezz13
Car: Had 2004.5 Nissan 350z
Have 96 f250 and mommas 07 Murano
sir_vq wrote:whats up new to 350z crowd but need help when accelerating in low mid rpm range and turnig slight right my power steering starts to scream and it feels like there rocks in it if that helps fluid is good i took off the p/s cap and fully turned the wheel in both directions turn tryin remove any air anyone got any suggestions on possable problem
WTF is that?... love to help but seriously, WTF is that ^^^^ please rephrase, add puntuation, and repost
sir_vq
Car: 350z
ok here i go. when i make a right hand turn my power steering starts to fight back and makes a whiney sound, this only happens when making right hand turns and while slighty excelerating, i have checked for air, tire rubbing and the tires in general, also belts are brand knew and have good tension, what else should i check
sorry about previous post not being so clear, but i appreciate the responses please help
dasoupdude
Car: 2005 Nissan 350Z
Only turning right you say?
its probably something rubbing against your wheel, might want to check for any excessive wear on the inside.
marlin29311
Car: 2008 Infiniti G35x
Is your PS fluid at the right level?
sir_vq
Car: 350z
no today i happen to talk to someone who had one for many years. so he as seen some of the issuses that come up, it turns out its a wheel bearing i jacked up the car and the driver side wheel has play so i thinking the man was right on point
funny thing is once i said it felt like the pump was grinding rocks(like in original post) he immeadiatly said wheel bearing!...... thanks>>>> to all who tried helping
Return to “350z / 370z Discussion”
