pnoman »
https://forums.nicoclub.com/pnoman-u67393.html
Tue Jun 05, 2007 4:43 pm
Greetings. I'm new to this site, having just bought a used '95 Altima GXE with a 5-speed. It has 129K miles, but the engine runs great and the car is in pretty good shape.
However, (and I knew this when I bought it - cheap!) there is quite a bit of gear whine and there is a leak in the output shaft on the driver's side. I went to the auto parts store and bought a rebuilt driver's-side CV joint/halfshaft, and a new oil seal. The old shaft boots were rotten and ripped open, and the CV joints were about dry.
After replacing all the pieces, I'm still getting a gear whine similar to when a power steering pump runs low on fluid. It stops when I depress the clutch pedal, and quiets down at highways speeds. It also does not make the sound when the clutch is depressed and the engine is revved, so I think it's a transmission problem. It's also still leaking trans gear oil down around the output, enough to create a 4-inch-wide puddle overnight.
Any help would be greatly appreciated. I know this car has another 75-100K in it, and would like to fix it up for my son to take to college. BTW, I'm in the St Louis metro east area (by Scott Air Force Base, where I just retired after 20 years of service) if you know any good shops, in case it needs serious surgery.
Thanks!
pnoman
