Please Help on MSD Blaster SS
Laozilvia
Car: 1989 S13
I thought that I saw a thread on this subject but now seems like I can't find it. Does anybody know where is it at or have a wiring diagram? I'd checked at msdignition.com and could not find anything there. I am installing on s13 ka-e. Any info would be great. Thanks in advance.
Oh.....after installing my 89k ka-e......everytime I step on the brake, my cluster lights up and chime like I have the door open. I've been trying to figure this problem out for about a week now and did not come up with anything. Any ideas?
180fan
Car: 89 fastback
post that first question to the KA guys. I'm not familiar with the MSD stuff.
Sounds like you've got wires crossing behind your cluster/above your feet. Start with the brake switch and follow it to where the lines meet up with the chime box's wires.
Laozilvia
Car: 1989 S13
I think I'd check on that but for the sake of it, I'll do it again. Thanks.
Beazle
Car: 1995 240sx
There is a plug that goes into the stock coil. This plug has 2 wires. One is negative and the other is positive. Use a volt meter to find out which one is positive and which one is negative. iirc the black one is positive and the green negative, at least on 91-93. Hook these wires to the new coil positive to positive and negative to negative. The MSD papers speak of a ballast resistor and I can't help you there.
Laozilvia
Car: 1989 S13
Actually one of the wires that goes to the stock coil is a tach wire. I know that the other is the positive. The negative is the one that clips to the body of the car. Thats what got me worried towards splicing the positive wire. I don't know what to do with the tach. I don't know if I should just go by the conversion diagram for the de or not. I might try that and see what happens.
Beazle
Car: 1995 240sx
Well that's good to know. Two of my friends are running it the way I previously stated and they are working fine. I don't have any long term experience with it though considering we just hooked it up about 3 weeks ago.
