My RB25 »
https://forums.nicoclub.com/my-rb25-u61932.html
Sun Jul 08, 2007 1:04 pm
Basically if you set your engine to TDC before hand you should be ok (please someone correct me if I'm wrong). I did my timing chain last weekend, took everything out (dist, dist drive gear, oil pump, etc.). Actually I set my to 15* BTDC (20* on the DE) (2nd mark to the right of the pulley) and she runs fine, with the exception of a small oil leak around the pan (I didn't remove it for the job), which I expected, but I'll be replacing the pan soon anway.
Just when you go to mark up your engine, make sure you have the - battery terminal disconnected (don't need the engine turning over on you when your turning it by hand...) and just turn the crank with a 27mm socket and a 1/2 in ratchet or breaker bar, depending on how hard yours is. Either that or disc the coil wire and blip the ignition switch a few times till your marks are close, that way your not turning the whole thing by hand.
Also remember, just cause the crank is marked tdc, doesn't mean #1 cyl is, it could be the fourth. With straight down plugs is the easiets way to determine this, but I guess it could work on the KA. Put a screw driver (long one) in the #1 cyl spark plug hole, turn the engine (by hand) and watch the screw driver, it'll bob up and down as you turn the engine. Watch till it peaks and then starts to fall back down. Get the screw driver to completly peak, your at TDC on #1. I also believe the rotor on the dist points toward the driver side strut tower or near it when at TDC (look at your cap to see if has a mark for #1, then see where the rotor is pointing in relation to the cap), done. Just note how everything looks when you take it out and make sure it looks the same way going back. Oil pump isn't a hard job. BTW the name of that stuff is Permatex High Tack Gasket Sealant, just work quickly with it, it dries quickly.
