FliMSiCaL »
https://forums.nicoclub.com/flimsical-u15768.html
Wed May 18, 2005 6:56 pm
if you have busted fuses, check the hidden, always troublesome ecu fuse. if this is electrical, the pop would be a massive short caused by something like a worn starter cable or the like, which would pop lotsa fuses. also, when u missed, did you overrev the engine? Do a compression check to see if you might have blown something...
