AlabamaDan wrote:Where exactly are these (door lock actuator) and what do they look like? I suspect I have at least on bad one as the doors have a tendancy to lock themselves. I looked in the FSM and couldn't find them.
I looked in the FSM in the EL and BL sections and there's lots of troubleshooting descriptions but no real picture. I've attached one below.
You'll be able to see it easily once you remove the door panel. It's inside the door attached to the locking mechanism that contacts the striker. You have to remove the entire locking mechanism and then detach the DL actuator when its out of the door. IIRC, the window regulator and window channel have to be removed to get to it.
I'd like to here from some of the experts on this but I don't think that the Power Window Amplifier (LCU-xx) mounted in each door of the 94-96 would have anything to do with the door locks. It should only control the windows but the FSM has you checking the connection before starting the diagnosis. Tech? Wes?
