please help... need to know what this is!
siks13sr
Car: 91 hatch. RB in the works.
Hey everyone...I have an 89 240sx. Im trying to figure out what is below/infront of the master brake cylinder, right behind the ignition coil, . im swapping in the sr20det an im not sure what that is. Any help would be appreciated.
xns
Car: Computers and cars
could you be more clear, and maybe take a pic?
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
Your probably talking about the crap with the black box and tubes that go to the exaust manifold and intake box. Thats KA emissions stuff you wont need.
siks13sr
j spec tuner.. its right behind that crap... it looks like a pump or something an it has a hose that goes somewhere im not sure... sorry.. i pulled out the ka a while ago an im nto sure where it went
Axoure Dragonkin
Car: '92 Nissan 240sx se
I have an '89. I just looked real close.
The only pump thingy that should be there is AIV apparatus. Mine is gone. There should be 3 black hoses coming out of it. The 2 small black ones go toward the front of the car and the big black one runs back a bit then forward and into a metal conduit nearer the heat sheild, which if you follow runs into the down pipe. The pump is connected to the black plastic box which is connected to the air box.
The only other big black hose that runs near ther is some part of the cooling system and comes directly from the water pump then runs up and over where the engine was.
Assuming you are getting an SR20, the whole thing can be eliminated from the system and will leave no holes except for the down pipe, which should be replaced with something better as part of a full exhaust system. Plus it will clean up the engine bay some.
Someone tell me if I miss spoke.
Hope that helps.
siks13sr
dragonkin, i believe you are right... thanks for your help
Axoure Dragonkin
No problem.
