MinisterofDOOM »
https://forums.nicoclub.com/ministerofdoom-u16506.html
Tue Jan 19, 2010 11:14 pm
Is the computer shutting off, or just the screen? The reason I ask is the screen alone dying would explain the need to remove the power source before restarting. It would also fit with the "usb noise" as the monitor would be considered a plug-and-play device and trigger the sound when detected or removed.
Do you have an external monitor you can connect to it? If so, hook up the external monitor and tell windows to mirror your desktop on that monitor. Then see if the problem persists. If it does, try disabling the built-in screen and using only the external monitor and see if it STILL persists. One of your function keys will allow you to switch between the external and built-in monitor. Or you can go through your Nvidia control panel to access various multi-monitor settings to switch monitors or set the external to mirror.
It sounds like you have a pinched ribbon cable. If the laptop is still under warranty, I'd send it in. Otherwise, crack it open and see what you can see.
