Boorah »
https://forums.nicoclub.com/boorah-u118211.html
Tue Aug 04, 2009 7:56 pm
I've been trying to search for a LONG time now, but I haven't had ANY luck, so im sorry if these have been discussed before.
So again, ANY help is much appreciated!
1. Im having a problem where if my lights are completely off and I hit the brakes, all my parking lights come on. And if I already have my lights on, the brake lights are on as if I was hitting my brakes. So its a big problem at night when im driving and it looks like Im hitting the brakes all the time. Im sure its a wire crossed somewhere, but is there a problem spot that I could check first?
2. I have NO power inside the car unless the key is on the ON position. I can turn on all the external lights, but no power inside the car. This makes it annoying with the power seatbelts, and the clock resetting everytime. I assume this one is a fuse, but which?
3. E-brake, only the passenger rear wheel gets locked, not the drivers and if I slam on the brakes hard enough to lock up the tires, the car goes sideways instantly.
4. Smoke, the car throws out a WHOLE lot of black smoke ONLY at the very top of first gear right before redline as soon as I push in the clutch, but it doesn't do it in any other gear. Injectors?
5. Cig lighter, won't work, fuse is good. Not really a big deal.
4.
