lbrowne wrote:Thanks for your help. How hard/long of a job to do the bearings?
You pull the trans out then drop the oil pan and you can unbolt every thing to drop the crank besure to note location and direction of caps. inspect the crank journals for any signs of wear if ok you can throw a new set of bearings in. the crank will have the grade bearing to use for each journal stamped into the front crank lobe.
Quote »Plus, as the car sits right now, how much time before she shuts down if I can not do the work yet.... [/quote] hard to say without hearing it first hand.
