(Already Solved)Transmission Issue
Dedicated to the G37 Convertible. This forum is for convertible-only content that is NOT covered in the other G-Series forums.
Leo5350
Car: G37 Convertible 7AT;FX35
Dear all,
My vehicle is G37 Vert with 7 AT. Mileage is about 18,750 mile / 30,000 km.
However, my vehicle's transmission has been into "Safe Mode" 3 times, when I'm driving over 30 minute; and push harder on the gas.
The computer shows "P0735 - 5th. Gear Malfunction". http://helpforcars.net/obd_codes/p0735_infiniti.html http://www.infinitig37.com/TSB/ITB10-075a.pdf
Nissan told me "The transmissions of G37S and G37 Vert are different! They need to get a new transmission from Japan!"
The cost of this new transmission will be over USD 11,000.
I'm not sure I need to pay for this new transmission or not because Nissan doesn't answer me, yet.
My question,
1) Can I use "G37S" 7 AT transmission?
2) If I want to buy used/OEM "G37 Vert transmission", where can I get? (I couldn't find it from eBay)
Sorry about my poor English...
RicerX
Car: '20 Titan Pro4X
Welcome to NICO!
As long as you don't have any extensive modification to your vehicle, I would imagine Nissan would replace the transmission for you under warranty. Your car has relatively very few miles on it to run into this kind of problem. I highly recommend you wait for a final resolution from the dealer and allow them to replace it with an identical OEM unit. I don't see a reason to be worrysome just yet! Hang in there.
Leo5350
Yes, it's under warranty. I don't need to worry about anything.
Thanks.
cmesurf
Car: Infinitis, 03 FX35, 07 g35 sedan, 05 FX45, 09 G-vert & 14 Q50S Hybrid AWD
your should be covered under warranty, I doubt you'll find trany for the vert unless it was totalled..
Return to “G37 Convertible Forum”
