Exar-Kun »
https://forums.nicoclub.com/exar-kun-u1725.html
Thu Sep 29, 2005 10:06 am
Put the car up on jackstands, you should be able to turn the wheels fairly easily at rest (do not put on the e-brake)...
If you cannot, something is grabbing (which it sounds like it is). BUt it would be unrelated to the vacuum lines, etc it's somnething physical (like a stuck e-brake cable, etc)
If this is OK, start the car and try to turn each tire. If it doesn't turn easily now, it may be the vacuum booster causing an issue (I would heavily doubt it).
Also, are the rotors extremely hot after driving? The small nubs on the rear (INNER!)pad should line up and fit into the dimples in the rear caliper piston. If not, there's a problem.
I assume the pedal would be hard, etc on the car, not soft?
-0Chet
