mersidoe »
https://forums.nicoclub.com/mersidoe-u9692.html
Fri Feb 06, 2004 12:36 pm
Sorry to be such a whiner, but this hasn't been my week for cars.
I have the J30 with the spurting radiator, followed by the rough idle and the check engine light. We weren't sure whether to tow it to the dealer that had just replaced the timing belt, or the tire shop/mechanic that treated me to the display of shooting anti-freeze.
I started with the tire shop/mechanic, because he said to look under the hood, and if there was lots of anti-freeze, maybe the leaking coolant shorted something out. Well, I did see a lot of coolant under the hood, so I had it towed over there. However, when it got there, he said there wasn't enough fluid to do any major damage. So he said they'd do some diagnosis....
Fast forward to today. They said I had a bad injector - I don't remember if he told me which one.
Short of becoming a master mechanic in a short period of time, which I've considered, but realize is impossible, I feel like I'm at the mercy of what they tell me.
First of all, is there any other troubleshooting I could do (or ask them to do) to confirm that is indeed a bad injector, and not bad gas or something else? Secondly, he's talking about just replacing the one - but when I did a search on the site, I saw some threads that said that with J's you have to replace all 6 at the same time? Is that true?
Finally, their quotes were about $750 parts and labor to fix the injector, and $750 parts and labor to replace the radiator. (Their labor is $77.50 per hour.) Fair, or should I keep looking? If I have both done at once, should I be able to request a break on the labor?
Thank you all in advance for your help. I don't think I could make it through all this without your words of encouragement. Hopefully I'll be able to return the favors.
