Zwicked »
https://forums.nicoclub.com/zwicked-u65277.html
Tue Jul 21, 2009 4:12 pm
****BY THE WAY...the manual says for testing the AAC connection: voltage briefly decreases from battery voltage 11-14 volts when the engine speed is raced. EF&EC section, page 173
I would take a multimeter, set it to the 20 VDC range, and insert 1 probe in each of the 2 connector contacts and run the engine and see if you get a voltage reading before pulling the ECU out.
I would still recommend you first check the Air Reg and the connector cleanliness. It only has 2 bolts holding it on and no gasket. Once it's off, take and hold it up to the light. You should see a sliver of light coming through. Next, connect it to 12 volts and wait about 5 minutes. Now when you peer through it, the sliver of light should be gone. If that's the case, all is well. If not it's gummed up or burnt out. They can gum up in the closed position and not allow high idle when not at operating temp.
Did you run o2 diagnostics as you mentioned? I remember when mine were bad it idles poorly and smoked a lot, not that it stalled though. Still worth running the diag to be sure. It's nice to have everything confirmed working and in spec to make the search of faulty items easier.
I think the auto ECU can be used in a 5 speed but not the other way around.
Removing the ECU is the same as disconnecting the battery as far as wiping anything out and relearning goes. No biggie.
Disconnect the battery before removing the ECU connector. The ECU has 3 bolts holing it down, and then you can get at the connector which has a 10mm bolt holding it in. It needs to be unscrewed and then pull on the connector while doing that. I would run a piece of wire from the AAC plug to ground and use a multimeter or continuity tester just to prove out that the wiring to the AAC is ok.
When you reinstall the ECU connector, make sure it goes in nice and straight and go easy on tightening the 10mm bolt back up, but do make sure it's 100% seated or some things won't make contact. I found that out once and the fuel pump wouldn't run.
Modified by Zwicked at 7:40 PM 7/21/2009
