PLease help me!!! Here's some pics!
Enemigo
I had a standard S14 BB T28 in my s13 and went to crap, so i got an HKS turbo, dunno the actual model but its exactly like the stock t28.. My only problem is that the J pipe (dump pipe) does not match the other turbo. Basically the 5 bolt side on the exhaust doesn't fit the pipe i had.. What can i do? I can't find flanges on the HKS site.. i really need help.. Maybe someone here has 1 for sale.. or maybe can weld me a flange.. i dunno..
As you can see the 2 bottome ones by the WG matches up but the top 3 don't line up.. help me.. is there like an adapter?
Jose
Silvia007
Car: 93 Nissan 240SX SE Fastback
Damn, you sure are screwed. What I would do is bolt the two bolts to your downpipe and weld the sucker on there. Although it is rather hard welding cast iron, can be done though. Do this because you can get a dump pipe anywhere should you decide to go back. Unlikey if this turbo serves you well. I'm sure a nico member in CA has some sort of a MiG welder.
