p00t »
https://forums.nicoclub.com/p00t-u5026.html
Mon Nov 03, 2003 8:02 pm
tie rod ends are easy, take off your front wheel. if you have someone turn the wheel back and forth you will see a rod that moves back and forth which is connected to the axel by a knuckle/ball joint. this is the tire rod end. The tie rod controls the back and forth movement of the wheel when you are steering.
for example look at the 2nd pic on the page you linked us to. you see that small bar thats horizontal in the picture and has a boot on it where it connects to the power steering stuff? that metal rod is your tie rod. if you follow that out towards the wheel the joint is the tie rod end (cut off in the pic).
