PLEASE help me find the fuel pump relay!!!
Colts_rule
Car: 1994 Infiniti J30t
We own a 1994 Infiniti J30t. A few days ago, our car starting problems began. I have tried changing the fuel pump, and filter. I was lucky enough to make it home but it wouldn't start back up. All the car would do was turn over. The fuel pump doesn't hum like it's trying to prime or anything . We bought a fuel pump relay today and all we can find is a diagram that shows it on the left side kick panel by the emergency brake. Neither myself or my wife can find it. I don't know if it's behind like the fuse panel or by the steering column. Please help us! I need to get this car back on the road.
Bubbaman
Car: 1997 Nissan Pathfinder 4x4
The fuel pump relay should be underneath the hood on the driver side. If not check the other side. There will be a black box about 8 inches long and 4 inches wide. I hope this helps you.
fourdrinie
Car: 2019 Q50
are you referring to FPCU? fuel pump control unit? or the fuel pump fuse?
I do not believe there is an actual square relay.....can you post a picture of it?
Colts_rule
It is not the fuse under the hood. What we bought from Autozone was a relay. Not sure about the FPCU. Is that in the trunk next to the pump?
fourdrinie
Car: 2019 Q50
yes, FPCU is in trunk next to pump
fourdrinie
Car: 2019 Q50
found it....driver's side kick panel, buried under A/T control unit...if you cant find it....look in the FSM, electrical system page 268
fourdrinie
Car: 2019 Q50
Colts_rule
First of all, I want to thank you guys for the quick replies. This is great forum for help and information. Now back to my problem... My wife had printed off the same picture that fourdrinie gave me. Neither one of us could find the relay but we both thought it might be behind the box. Now is there any advice besides undoing the battery before taking this apart to get to the relay. Could this be something else like the FPCU? Or what should I try next. Thanks again.
fourdrinie
Car: 2019 Q50
could you send me a picture of what you got....send it to [email protected]
Colts_rule
I am sending two pictures from my daughters phone. Thanks for your help.
Colts_rule
I found the relay. Switched it out and unfortunately that isn't the problem. Still no noise from the pump with the key turned on. Can anyone help me with the FPCU or do you think it might be a faulty pump that I have?
Colts_rule
The car is fixed. I went and bought a tester and was getting voltage to the pump. I returned the old pump and she starts right up. Thanks for your help again.
fourdrinie
Car: 2019 Q50
Did you replace the fuel pump?
Colts_rule
Sorry Yes I replaced the fuel pump.
fourdrinie
Car: 2019 Q50
Did you use a new O-ring?
