Please help me connect the right wires. Very easy to help. Picture makes it easy!
DbD
I just got a new universal wiring harness for my MAFS (I got it from the dealership), and the wires have different colors. I don't know which ones go were so could you please look at your wires going into the MAF sensor and tell me which ones go were. That is which color goes is on the left/middle/right? This is for a SOHC 240, but the wiring should be the same for all models.
This picture will make it a lot easier to figure out what i am talking about. This is a front view of the MAFS as it would be when it is screwed into the MAF assembly. Please Please Please help me out!
thanks,DbD
slow s13
Car: cars, photo, music
If you look at the conector that conects to the maf with the open side toward you and all the wires going away from you, with 2 notches at the top and one notch at the bottom from left to right it is. White,black,black/white
DbD
You are a GodSend! Thank you so very much.
if you ever need anything let me know,zac
