dmartin1 »
https://forums.nicoclub.com/dmartin1-u199260.html
Tue Mar 05, 2013 8:55 pm
ok, so i put a new fuel pump and screen in my '93 j30.
it fired up and ran ok.
but it idled at 400rpm or so and a bit rough? no loss of power or anything through the acceleration and was smooth on gas.would periodically stall at stop signs but fire right back up.
i drove it around my neighborhood a few weeks and one day after i got home, i went out 30 mins later to start it, and it just cranked and fired, trying to start and would read 150 rpm on tach, but die as soon as i let off the starter.
its been sitting a few months now, i put fresh gas and wont do anything at all now.
what i have checked-
Its not throwing any codes.only 55 which reads as no fault.
its getting spark, strong on every cylinder.
good compression.
new fuel filter on passenger inner fenderwell
fuel pump kicks on and primes when key is turned on
its getting gas.to the fuel rail, but after that IDK the plugs arent wet at all.dry as a bone
what does it sound like?
please help me and walk me down the steps on this bad boy.
check engine light is on, and so is the AT CHECK light when i crank it.
