Please Help! m37s part needed
Oberon5
Car: 2012 M37S
My 12 M37s has a bent inner tie rod, driver's side rear. Infiniti does not have this part listed separately, they only sell the entire rear "steering rack" for over $6000!! I'm panicked, we can't get the wheels aligned and it has already eaten 2 tires at $335 ea. Please help me figure out how to get this part, if it is something that can be replaced. It looks just like any other tie rod until you get to the rubber boot where it ties in to the steering system. Do any of the other rear wheel steering Infiniti models share common parts? I figure I only have 2 options- a wrecking yard who will separate the rear steering rack parts or the aftermarket (not likely).
Thanks for any info you can provide!
Oberon5
Car: 2012 M37S
come on guys! Someone must have an idea here!
Oberon5
Car: 2012 M37S
Here's a pic
Panzer Leader
Car: 2012 M37S; Formerly owned a 1994 Infiniti J30t and 93.5 G-20.
Try Rock Auto Parts..... Looks like they may have one. If not listed call them. I cannot understand why Infiniti does not sell as separate part. I would also call Infiniti direct. Only other chance is a salvage unit from a wreck. TRY INIFINITI PARTS USA.COM Check out the section under REAR SUSPENSION COMPONENTS
