smokin240 »
https://forums.nicoclub.com/smokin240-u15929.html
Sun Jan 16, 2005 11:38 pm
My 93 240 just doesnt have any "snap" to it at low (under 2300) and high (over 3300) RPM after about 3 minutes of driving it, basically after it warms up (which I think is the key to the whole thing). But, when I gear down to second going about 45ish the exhaust pops and passing about 5500 RPM the engine seems to kick in and actually throws me back in the seat, like it should all the time. Any other time its really sluggish (other than when I just started it up) and it also smokes extremely bad the first time I drive it and drive it hard but I think thats due to the thick oil I put in it to help the engine tapping. In fact if I stomp it to the floor it’s actually more sluggish than If I ease into the pedal. I have to rev it a little more than normal to get it moving from a dead stop because the engines dogs out so much. I’ve tried the MAFS but it was from a used car, that didn’t help. I’ve checked the rotors and cleaned the erosion off, still no go. Also tried replacing the coil. I think I have narrowed it down to three things, clogged cat, bad injector(s), o2 sensor, or fuel pump and maybe possibly a vacuum leak. I really don’t have the money to dish out and fix all these problems so im hoping maybe someone has had this exact problem before or seen it and knows how to fix it. Not to discourage anyone but i’ve had 5 or so mechanics actually look at it and try to guess whats wrong and I lost count on how many i’ve talked to about it and they can only guess. This has been going since i’ve had this car and this is the last attempt im going to try and fix this, if no worky then im selling. It’s suppose to be a sports car not a sentra with real wheel drive. Thank you all for the help and hopefully i can finally get this fixed.
