ARKQX33V6 »
https://forums.nicoclub.com/arkqx33v6-u165721.html
Fri Oct 07, 2011 6:44 am
QX4Marsh, the operation of the engine and then a seemingly choked shut down could be timing is off.
You moved the distributor and thus the timing is likely to be mal-adjusted. You can not get it started so,
Charge the battery
When charged, try aligning the distributor rotor to #1 position then see statically the position of the timing marks on the flywheel damper are anywhere near the alignment mark. If so your timing belt is still attached, but with mileage that you indicate you are on borrowed time with that timing belt.
The distributor may look clean but at that mileage if it was never blown out or disassembled the LED and receiver will have a haze of crap over them and the emitting light may be a weak spot.
The slotted wheel inside may be covered with dust.
Your ignition system is still working, but your power transistor may be failing.
When you adjusted the distributor was the engine still cold? If yes, check the idle air controller, it may be fouled as is everything to do with recirculating exhaust, by-pass air and throttle condition.
You need to verify 1 thing at a time and progress until all things are verified. Remember that if the timing belt is worn or stretched the cams will be off, thus the valves will be off. If the timing is off more than a cog on the belt the motor an interference fit design can be catastrophically damaged with punched pistons, bent valves and a very large repair bill even if you do the labour.
It sounds as if this motor is heading towards failure according to your posts and caution is needed to possibly stop any further damage, so be very careful and make sure that the timing has not been upset to enable internal collisions.
