Please Help? Just starting
iloverbpowers
Car: Nissan Cefiro 1989
Hey Everyone
I got a 1989 Cefiro and love the bloody thing its running a rb20e at the moment off a 1998 r33 ((hehe did a swap earlier))
I recently bought a RB20DET off this guy on trademe.co.nz The engine came out of a Cefiro and Came with the following
3.5in Full Exhaust systemEngine itself and all the turbo and wastegate etc bolted onto side of it.Standard
Standard size FMIC and Blue PipingPower Steering Pump and Alternator20det Fuel Pump20det Cefiro Loom20det EcuBlow off Valve
Since no flywheel was included i found one which is "Flywheel 9 bolts on outside and 6 bolts in the middle for 145$"It needs a skim so i found a machine shop to do it for 45$
at the moment the Cefiro is a Automatic so since the engine is a manual its worth going manual straight away? unless i can put on my auto although what do i need to do to just put it on? its alot easier then dumping so much money into a manual conversion which i do not have at the moment
Can i reuse the Flywheel and gearbox i got at the moment off the Rb20e? or? and what would i need to do to bolt it all up and just keep it auto for the time being?
So please guys help me out hereWhat else do i need to complete this?and get it running?
iloverbpowers
Someone Give me a Lowdown on Whats needed for the Manual Conversion That is ofcourse if i got the Flywheel and Gearbox already
and If someone could give me a Lowdown on Whats needed for me to get to add to that list.
Thanks Paul
Sil240
Car: Nissan S13 "The One Cam Wonder"
You'll need a clutch pedal a brake pedal and a manual dshaft also manual interior piece
Kevin.A
Car: Nissan 300zx RB20 swapped
your also going to need a master, and if it didn't come with the trans, slave cylinders and the lines to connect them.
totomon78
Car: a31
Hi,
do you still have the ecu and harness of your rb20e and the injectors? wanted to buy those if you want to sell them..
thanks
iloverbpowers wrote:Hey Everyone
